I want to add a RTC report to Role Center->Reports, which page should i use? i am successfully adding to other pages but for Role Center i am not sure why i cant see it. The user i am using is super.
You have to realize that roles are not identical or by default linked to any role center. You can link a role center to a (windows) user and you can assign roles to a (windows) user.
The user is SUPER user. i just want to add a report to RTC->Home->Role Center->Reports thats all. I am able to add else where like Item List, Customer List etc but not in RTC->Home->Role Center->Reports. So what i have to do?
thanks,
OK.
- Determine first which role center you want to add it to (there are 21 of them i.e. Page 9000 to Page 9020
- Then decide whether to update the corresponding Form or Page object
- If Form add the report to the Report menu button and (re)transform that form to corresponding page (note: if you have local language strings on the original page export them - using translate export - before replacing it with the newly transformed page)
- if Page add the report to the action (subtype Reports) - you can open the actions window from the Role Center Page in design mode: click the first empty line and then through View menu > Actions
Hope this makes sense.
Are you saying the username is SUPER or that it is a user with the SUPER role assigned?
Users are linked to Profiles via the User Personalization Card Form. Profiles are Linked to Role Centers on the Profile Card Form. If a user is not linked to a Personalization Card they get the Role Center marked as Default.
