Uplaod a file in NAV
Can anyone tell me if it possible to uplaod an excel file in to navision?
For example if we can draft a Bonus Journal excel sheet and can uplaod it in Navision General Ledger/Job Journals? instead of entering each transaction directly into Navision?
If yes, then i need a step tp step guide on this.
Thank you very much
Fahad
Hi Fahad,
You could save the file als ‘csv’ from Excel and create a dataport to import te data if you’re using classic NAV. If you want to use it in the RTC, you’ll have to use a report or XMLPort to import the data.
You can also use XML port 5050.
Check this post:
http://dynamicsuser.net/forums/p/27479/146954.aspx
learn from export/import budget excel.
