importing data to Navision
Can anyone help understand how I can import a .xls or .csv file into Navision to create a payable to a Vendor and to import data as a journal entry?
You can use dataport or Excel Mapping tool or Data validation to import frol .xls or.csv file to Journal.
You need to dataport using Table 81 .
Amol
Hi ,
If you want to aviod programming you should use the mapping form (form 8601).
That can deal with Excel imports and exports and you only need to do configuration (no coding).
IF you dont have the form 8601 then ask your partner to import it !
regards,
Gabor
