Got another error in NAVision whent trying to use MS Outlook Integration.
Could not create an instance of the OLE control or Automation server identified by GUID={316692C7-ABC7-4929-AF58-68C1D274E6A9} 1.0:{E9B8EFD3-ABC7-4C4E-A0B4-1998B764DBBF}:Unknown Automation Server, Unknown Class.
Check that the OLE control or Automation server is correctly installed and registered.
The Outlook is working fine even before th NAV was installed. What version should we install Outlook? do we need to install it in both machines. (Server and Client workstation)? Can I have a copy of the procedure for this?
Thank you so much for the continous support, really appreciated.
One further query - did you install the Nav client or just copy the Nav Client directory and/or create a shortcut to a nav client folder. If so the easiest solution is to do a client install.
