Hi all, I need to create a turnover report based on the G/L Entries amounts of one particular a/c only. But the problem is that I need that the total of each month of the last 5 years are given.
For example if the user needs to see 2009 turnover, the report will show Jan-Dec of the last 5 years. Any hints of how to go about it?
Analysis by Dimensions is your friend here. If you don’t need Dims, simply ignore them, you’ll get G/L Acc amounts not subdivided by Dimensions.
Then, select Export to Excel (under Functions). This will create not simple rows/cols with data, but an Excel Pivot table, where the posibilities are muc more to slice & dice yor data, format them and if needed, print it out. You, however, must have some skills working with Pivot Tables in Excel, of course, but that’s nothing very difficult to learn…
I think u can use Account Schedule for this, will be easy as u can set ur Column layout in A/c schedule itself and have ur calc done in NAV and then export it to excel.
Acc Schedules are not so “elastic” as Analysis By Dims and:
you need to create many Colums with fixed Comparison Formulae like -1FY, -2FY etc and these are tricky to set up them as needed (help is poor about setting them up, even not all “keys” are enumerated - FY isn’t in help, but it is legal there);
export to Excel is flat, not Pivot table, so no additional “slicing & dicing” is possible
So, quicker solution IMHO still remains Analysis by Dims…
