I am really new in this Navision World, I hope that some body can help me to get known with Navision.
Her is my Prosject, I have to develope a .NET application that will communicate with Navision by use of Navision Application Server. We have received a demo CD with alle Navision 4.0 SP2.
I did install Microsoft Business Solutions-Navision and MicroSoft Server Option for Microsoft Business Solutions-Navision
I can see that a Database with name Navision Demo Database(4-0) isinstalled in my Database engine( local)
then I did install NAS, but when I try to create a SERVICE as it says in the documentaion( ex:
nas appservername=nas1, servername=srv1, company="Cronus
International Ltd.", startupparameter=p)
and I get the following messege
C:\Programfiler\Microsoft Business Solutions-Navision\Application Server>nas.exe
appservername=test1, servername=BARCA, company=“testCompany”, startupparameter=
p
Date: 22.02.07
11:06:14:
11:06:14: Navision Application Server version 4.0 SP2 (Build 22100)
11:06:14: Copyright (c) 1987-2006 Microsoft Corporation
11:06:14:
11:06:15: The TCP/IP connection’s ‘host’ is not answering (TCP/IP error ECONNR
EFUSED).
11:06:15:
11:06:15: You can see how to make changes to your ‘hosts’ and ‘services’ files
in the documentation for the network. Contact your system manager if you need a
ssistance.
11:06:15: The Navision Application Server test1 could not initialize properly.
11:06:15: The server will attempt to initialize every 30 seconds until this is
successful.
11:06:15:
As it sayes I have to make some changes in my host and services file, what changes I have do!?
I believe that I have to open some TCP port in services and make som references to server in host!!! but how or what?
In general, if you are not able to connect to a DB, add NETTYPE=TCP. This because since version 4 (I think), Navision uses TCPS as default … but I have never seen it working…
If it is a test DB, no problem installing both on the same machine.
If it is a production DB, it is best to avoid it, because the NAS can use the CPU, memory, disks that are needed for the DB-service. But most customers don’t want to buy a machine for only the NAS, so…
Now I have oter problem and mainly its about license fil, I get these to warning on my EventLogs
The operating system cannot find the fin.flf
please heck that the driver, directory and file name are correct
You have not selected a database
I am sure that I have this file in my istallation folder and I have a CRONUS.FLF file in the same folder and I tried to use this(rename this as fin.flf) but I get same result, any idea!?
You did not set the right parameters for your NAS service. There is a folder on the NAV product CD called ‘Doc’. In this folder oyu will find a pdf called w1w1ATAS.pdf. Read this entire document and try to figure out what went wrong. Good luck [:)]
my issue with License file is resolved but I have this old prblem again, tons of the following warning in my Event logs
The TCP/IP connection’s ‘host’ is not answering(TCP/IP error ECONNREFUSED).
you can see how to make changes to your ‘hosts’ and ‘services’ files in doc…
and my hosts and services are the same, I am confused!!!
Is this problem have any thing with DNS and AD!? here is the scenario:
my PC is member of domain at the office but usually I did not log my pc on the domain, I do log on my PC, is this a problem regarding the problem with TCP/IP!?
I did read the doc, I will go through doc agin to see if there is some thing that I overlooked.
