TCP/IP error ECONNREFUSED
Hello,
I am currently installing Navision 4.03 and I am getting a connectivity error “The TCP/IP connection’s ‘host’ is not answering (TCP/IP error ECONNREFUSED)” so I am not being able to access the Navision database through TCP or TCPS.
The configuration I used to install the service is the following:
“PATH:\SERVER.exe” servername=servidor, nettype=TCP ,database=PATH\DB.fdb, cache=900000, commitcache=yes, installasservice
The service is installed succesfully but when I go Into Navisiom / Open database and type the server IP address or name I get this error.
Strange thing is that it used to work when I had Navision 3.70 installed and everything worked perfectly with this service configurations.
Would anybody have an idea of how could I fix the error?.
Thank you.
Miguel
Hi Miguel,
Firstly, Welcome to the Dynamics User Group !
Sounds like you are doing an upgrade - did you upgrade the Database Server service from 3.70 to 4 SP3?
I’m assuming that you can ping the server “servidor”
Yes…
You are correct in both points, I am doing an upgrade and I can ping…
I think it might be a problem with the service. But don’t know any other way to create it.
Hi Miguel,
Just to be clear - did you install the version 4 database server?
Is the service running?
Yes I did, Version 4.03 for North America
Hi Miguel,
To rule out connection problem such as firewalls etc, I usually test the connect to the service on the server first. Can you try this?
Please let me know how should I do this
Hi Miguel,
Install a client on the server and connect via the service as normal.
I do that! that is when I get the TCP/IP error
Ahem…
