Hi everyone!
I’m working in AX2012 R3. I have a problem with an user that happens only with that user and in prod environment.
The user can´t see user defined source types in Opportunities form. The user said that before, he was able to see all the fields. There was no code changes. There were no roles changes.
User defined values of Source Types enum (smmSourceTypeList) has no configuration key, so it is supposed to be visible for ALL users. Only this user can’t see them.
Create a new user is not an option. I can’t debug since this is happening only in prod environment
I’ve tried to force the user to see all source types by giving him some of this roles associated to source type view privilege key. But all new roles changes, even system adminstrator role, are not updating to the user.
Did you had a similar problem? Thanks!
