Read only data source form AX 2009
I need to enable or disable to write the datasource of all forms if a specific user is enabled to make modify or not.
I do it, but some forms reloads it’s datasource in the init method, so my settings was lost.
There is any solution?
Use security that is built into AX.
Create a security group enabling / disabling access where required and then assign this new role to the user.
I solved putting my code on the Info class
