Can’t compile - Get a message that “You do not have permission to modify the ‘MBS’ MenuSuite” when we use “Create Item” in the Design Mode of the MenuSuite Object Designer, and try to save and compile it. Using SuperUser and a developer’s license.
The MBS menu suite object is not to be designed outside of Microsoft - you design one of the objects with IDs above this one (10), and your design is merged on top of the MBS object, and whatever other objects come below yours.
We were trying to compile on the region level instead of creating a Partner level. That was the problem.
