Hopefully this will be a simple question for all of you Navision pros out there!. I want to give access to a user create reports under the object designer but deny access to table and forms designer. Any ideas on how to achieve this? Thanks newbie
Hi I think these are setup under the permissions of the object type “System” (against the user assigned role ar one created for them)and you grant access to menu routes, i.e. Object designer, as well as giving them permissions to design reports and forms. Obviously super user has rights to all of this, and it is dependant upon your license. I have not set this up before, but it is where I would start - I think I would add the rights into the ALL USERS role and take it from there [:D]
