a lot time I got user complain when they created a Purchase Order, the “Expected Receipt Date” in Line was different with header. I know the “Order Date” on Line will follow up lead time to count and change the “Planned Receipt Date”. but I can’t find out what reason let “Expectd Receipt Date” are different from Navision Help. does anybody can help ?
Worth checking code in table 38 first as this is likely to be where fault is. Also check that expected receipt date on line starts off same as header when line created after header and header includes expected receipt date. If you see what I mean.
That’s interesting if you have compared the demo database to your live database. If they are the same object wise for table 38 and 39 then the difference is either in the P&P set up or on the page (some bespoke code) you are using.
