getting below error while trying to attached document on EP , i am using EpDocuList menu item directly in submenu and trying to use it.
Hello,
AX Document Management works based on the saved records… we need to save a record first and then for that record we attach document. we cannot deal with documents without the record reference… pls try to check the standard functionality for more understanding…
Hope this helps you.
Anil kumar
