can anyone tell me how can i buy the license code to work(development) in BUS layer? I mean which are the checklists(i.e. no of objects, kind of access rights on objects, objectID range etc)?
I am really unaware related to licensing procedure.
But when I have selected the VAR layer from the “Microsoft Dynamics AX 2009 Configuration” from “Administration Tools” and start the AX it prompts me for the “Access Code” which i do not have. So, I am not able to do any development in VAR layer without Access Code.
If you are a MS partner for dynamics AX, login to the MS CLT and ask for license. They will send you email with the license files and in the email body you will get the VAR/BUS… developer codes. These you need to enter into the client configuration utility.
But I just checked and if you are able to login to partnersousce as a partner you can generate/download license from there also. You need to click on the “VOICE” on top of the page and then go to the
My corporate information → Developer tools → License key configuration
Thanks for your support. I can go to “License key Configuration” but not able to select anything from “Program Type” and “Select Product Line” field. Also the “Product Editon” and “Major Version” fields are disabled.
Are you the administrator for PartnerSource in your company? If not, ask your administrator to provide you access to generate License file. If yes, you may want to ask your PAM for assistance
