I have created a workflow from the workflow wizard but when i go to create a workflow from the task like start it is not coming in approval please see the step 7 in here www.axpulse.com/…/ i got stuck in step 7 i am not getting the my object in approval??? an idea what will be wrong every thing looks fine thanks
Hi Rohit,
I think you have missed the Workflow–>Approvals creation,
refer to http://msdn.microsoft.com/en-us/library/cc596847.aspx
Then, Drag the create workflow approval element under Supporte lement of your Workflowtype.
Raghav.
Whenever you are creating Task or Approval element either manually or through wizard then you need to drag them into the supported element of your workflow type.In case of any issue do let me know.
Please don’t forget to Run incremental CIL
Regards
Pawan
