I am working on customization of new workflow in Dynamics 365 operations, the drag and drop of workflow approval type into workflow type supported elements is failing and unable to map my approval type to workflow type supported elements,
Can you please suggest if you any solution on the same.
Ganesh
Ganesh same situation occur with me any Solution?
finally i found the solution, right click on workflow type and add new reference, set respective workflow approval type in properties of new reference.
Hi Javid,
Thanks ,
It worked for me in the same way, but during My submit there is no action happening can you please share me if you have any document that you have followed to develop new workflow.
My email: ganesh.dynamicsax@gmail.com
Thanks ,
Ganesh.
Hi Ganesh,
I have share links with you. can you share screen shot with me how you submit workflow?
