Workflow Status is not changing to Approved !
After submission of workflow in Ax2012,the status is changing from Not Submitted to Submitted in Form and backend also.But after that when i am approving or rejecting nothing is happening except just one pop up box like submit.
After commenting Approved…am unable to see the changed status,not even table level.Then i checked the workitem details where i found that the workitem got approved by user.Then why status is not changing in front end and backend ?
Any idea why this is happening…even after putting breakpoint(after enabling workflowdebug true in macros),it isnot hitting to any respective ElementHandler->Completed or EventHandler->Completed.
Hi
I am facing issue as you posted. if you got solution for this issue let me know…
