How can i add Unit ID in inventory movement journal??
For all the inventory journals, System consider Inventory unit( which you set up for the Item) as Unit for the transaction.
If you want to show this unit, you may add a display method.
I tried to add the method statement from InventJournalTrans table, but giving error.
What do you mean “I tried to add the method statement from InventJournalTrans table, but giving error.”
I didn’t find the method with name Statement in InventJournalTrans table.
You won’t get reply unless you specify enogh details about the requirement,why you need this…etc
there is one method called ‘unit’ under inventjournaltranstable. I added a field and mentioned this method under InventJournalMovement form. But still not showing the unit of measure.
Please be more specific… Share more details.
What is the code? What are the properties on display method control? Share screenshots if possible?
You need to make a note that no one could waste their time by guessing for someone…
