While trying to open any report in AX I am facing this error:
"No connection could be made because the target machine actively refused it “192.XXX.X.XX.8201”
and I have double checked that the windows firewall is turned off and in the report serevr settings of AX , it is pointing to the right report server (and all the details are correct, becuse when I calidated the settings , it gave me a success message).
What I identified is the port number I see in the error message is 8201 while AX config file’s wsdl port number is 8101.
I suspect this could be the issue…
But I am not sure how to and where to change this port number to pick 8101 instead of 8201.
Thanks for looking into the issue. Yes, I have tried opening with both report manager URL and Web service URL and all the reports (whichever report I open ) display the same error message 'The ‘AX_CompanyName’ parameter is missing a value ', which I’m afraid is not the issue.
Hey what is the value for “permission set name” on the Report_Expressions_Default_Permissions in the rssrvpolicy.config file set to ? Probably it is set as “Execution”, if it is then change it to “FullTrust”
<CodeGroup class=”UnionCodeGroup” version=”1″ PermissionSetName=”FullTrust” Name=”Report_Expressions_Default_Permissions” Description=”This code group grants default permissions for code in report expressions and Code element. “>
Deploying any AIF services from AOT will start CIL compilations, So my above suggestion of redeploying “BIServices” covers that part. Probably the issue might have been resolved.
Archanae , if your problem is resolved --please close this thread.
