I have add customize fields in TrvRequesition Table with name RequestingWorker type int64 and add relation with HcmWorker.Recid so that on lookup i can get workers list. On EP when i select the one employee in RequestingWorker field and after fill up all the information in Travel requistion save and close the form then i opened it again RequestingWorker Field show me Empty against that requesition … What is the Problem that record is not save in Customize field on First attempt
