Im getting the below error while updating a record in a table.I have not written any code for performing this update.It by default calls the table’s update.
Kindly guide.
Thanks & Regards,
Chutti
Kindly guide.
Thanks & Regards,
Chutti
Unfortunately I can’t say what exactly is wrong in your code because you didn’t show it.
Hi Martin,
I have specifically not written any code for this update. I have just created a new table and added the newly created table as a data source in the HcmWorker form . When I try to edit a field value of this table from the HcmWorker form it throws this error.But when i update the same field in the table level it is working fine .
Thanks & Regards,
Chutti
HcmWorker table isn’t company-specific. I assume that your table is or you didn’t set the link to company correctly.
I can only guess without more information from you.
Thanks Martin.
Actually my custom table was company specific and that was the cause of the issue.
I changed it and it is working fine.
Thanks & Regards,
Chutti
