I have install the Dynamics NAV 2009 R2 on my machine (RTC, Classic Client, NAV Server,…)
I create a Page and when i try to Run the RTC Cronus (SQL Server) database opens but the following error appears.
The Object Metadata does not exist. Identification fields and values: Object Type =‘Page’, Object ID =‘50000’ ".
I have compile all objects, and i can navigate to role center and the standard pages as well.
Can you help me?
admin1
September 27, 2013, 9:12pm
2
I think you did the correct thing, but did you develop this object on a different database and moved it to this database? If recompiling that specific page doesn’t work. Then try open it, do a unimportant (like adding an empty line),change, save it and recompile it again in this database.
I have made a Item Card from the Table Item (27).
This database it´s the demo database that comes with the setup.
I have add a new line with the code:
MESSAGE(‘OK’);
Check whether same database is opening or not?
I close Dynamics NAV and when i try to open RTC client the folowing message appears:
Error message when you try to log into Microsoft Dynamics NAV: Your program license does not permit more users to work simultaneously
I have a developper licence and i see it on the classic client.
i restart the Microsoft Dynamics Server, and sustitute the fin.flf for our license.
But main error still continue.
Mohana,
what do you mean?
I open the database on the classic client and RTC, without problems.
Mohana i was open the wrong database.[:$]
I has a Instance call \SQLExpress
I have reinstall the dynamics nav and the setup creates an instance: SQLExpress.
Thanks for your support.
