i am New for NAv-RTC, i created one Table Sample, but When I Run the Object, its through Some Error.
" the object metadata Does not Exist.identification fields and values object Type=‘page’, object Name =‘50000’ "
Did you try by compiling all objects ?
yes i compiled … but still there is issue… No only that object … what ever i created 3 objects issue.
but one thing normal Objects(system objects) are wworking Fine
You need to compile all the objects at once & not induvisually, may be you can try with SA login.
