Hi All OK. I learned yesterday I can show the FileDialog in a Dataport with a Textbox (with Control ID = 1). But what is behind this? Is this a feature (like other hidden things e.g. system tables or bitmaps) for use only in the standard request form? Or can get I another hidden form or something else if I put e.g. 99999 in the Control ID of a Textbox? Can somebody enlighten me? bye André
What the heck are you talking about Andre, I placed a Text Controle ID 1 on a dataport, but it has no extra functionality. Just a textbox. Explain me man!
quote:
Put it on the Request Form with Assist = Yes and a Text variable. Bye André
Wow! Never knew that. Very good, very good.
Hi Emiel **
… as I said! But why? bye André
well I lied a little. I knew it, but forgot it. It’s a Navision feature to make the developers live more easy. I read that somewhere a long time ago.
…so how do you add the ‘Direction’ Import and Export option fields?
by adding Your own radio buttoms and using CurrDataport.IMPORT(TRUE/FALSE) in OnPreDataport [:)]
quote:
Better: Create your own form in VB - then coding your ‘Navision’ around [:D]. Bye André
quote:
Hi Andre! Personally, I’d prefer writing a VB COM DLL implementing the form stuff, then write a wrapper codeunit in Navision, then call this CU from your dataport or whatever [:D] WRT the magic textbox - I found this out the hard way (just like most other esoteric tricks inside Navision [8D]), then, a few days later, read the confirmation here in the forum. Must be one of these “documentation issues” we’ve been talking about recently [}:)]
