Dear All,
I got that error when submitting a purchase requisition workflow the security role is custom
Stopped (error): X++ Exception: Work item could not be created. Insufficient rights for user xxxxx.
at SysWorkflowWorkItem-create
SysWorkflowWorkItem-createWorkItems
SysWorkflow-save
SysWorkflowQueue-resume
Do you get the same error with the other work flows? We don’t know what your custom role has.
You need access to this table → Tables/WorkflowWorkItemTable
Do you have System user role assigned?
Yes he is he is a liked user
Here a snapshot from the permissions
What level of access do you have on that table?
in AOT correct is higher than create
I think Correct is designed only for valid state tables. (date time effective)
I tired a full control permission with the tables. and it didn’t work, so I test the built in system roles. It ave the same error with purchasing agent and only work with the purchasing manager. I tested the difference and a privilege named “PurchReqPurchaseRequisitionApprove”. I added it to my custom duty and it worked well. this is not optimal solution but later on I will compare my custom privilege with this one and identify the missing permission. and add it to this post for help anyone face the same problems. thank you Kranthi. I do appreciate your continuous help and support.
