Hi, I need to use scanner with Navision 4.00 on Windows XP. I must acquire a document using one scanner, my parameter is the file name. I have seen library ‘Microsoft Windows Image Acquisition 1.01 Type Library’ but I do not know exactly like using it, unfortunately in Windows XP does not exist the library Kodak Image Scan. Someone you would know to help me? Thanks in advance.
A simple solution would be to use a scanner that simply apears as a drive. I have a HP that once plugged into a USB port, it just looks like a Flash drive under XP. Hit the scan button, and a JPEG file apears inthe drive.
