Document scanning from Navision
Has anybody ever tried to call the scanner’s software from within Navision, in such a way as to avoid dialog windows and user interaction? The objective is to incorporate document scanning to selected documents flow. Thanks in advance!
How did you get on ?
Check the software provided with the scanner provides automation interface, if so you can try to use automation objects in NAV code
Cheers!!!
I wrote a .net control to drive scanner from navision and it works with all sort of scanner. Let me know if you need it or contact me on +44 7903832483.
