Is there any good solutions for scanning documents from Navision out there? The best way, I think, would be if the whole process could be controlled from within Navision and the image stored in a blob field.
I think you should take a look at: http://www.easy.de/eng!/sf8_partner_oem.html I have seen another solution from a NSC called EasyLink for NF - i can send you the pdf file i have. soren@nielsen.dk
Thanks.
We’ve created an automation controller which handles the job. You can download it at WWW.FALCON.NL\DOWNLOAD\DOWNLOAD_PICTURESCAN.HTM
Hmm, seems like the link is broken. Is the ocx still available for download? Please repost the URL. Best regards, Soren Nielsen, moderator Navision Online User Group
The link is available again, sorry for the delay! http://www.falcon.nl/download/download_picturescan.htm
