in Classic client menu suit Design we can assign users to each menu like we can hide some menus from some users.
i tried this in rtc client dept-mbs but still all menus are visible to all users. is it possible to hide deparment for some users
We need to create different roles and assign based on the user…remove departments menu from rtc…
You can not assign the users to menu in RTC.
we can add only lists to the role center,but dept menu contains reports documents tasks etc.
is there any way to add these to role center.
You can add under Actions…
is it possible to remove permission to customize navigation pane from user
You can use Disable Perosnalization command…
please check
http://blogs.msdn.com/b/nav/archive/2011/04/05/nav-2009-tips-and-tricks-disable-personalization.aspx
My solution was as follows:
2 Configure this profile to Remove or Add menu items (such as remove Departments Button)
To configure a profile in the RTC do this:
· Click Start and Type CMD, this opens a DOS window.
· Open Windows Explorer
· Navigate To C:\Program Files\Microsoft Dynamics NAV\60\RoleTailored Client (or path to the NAV installation files)
· Click on this file Microsoft.Dynamics.NAV.Client.exe
· Click into the Navigation Bar and copy the address above
Hello,
is it mandatory to set owner ID to open in Configuration Mode…?[:P]
Thanx,
Shravan Kumar
Hello,
Thanx,
Shravan Kumar
Yes
Hi Ramakrishna,
I made a detailed description on how to configure role center profiles and hide the departments menu in this post.
