An unhandled error has occurred. To view details about this error, enable debugging in the web.config file or view the Windows event logs.
The following system error occurred: A specified logon session does not exist. It may already have been terminated.
Microsoft SQL Server 2012 Analysis Services
at Microsoft.AnalysisServices.AdomdClient.AdomdConnection.XmlaClientProvider.Microsoft.AnalysisServices.AdomdClient.AdomdConnection.IXmlaClientProviderEx.CreateSession(Boolean sendNamespaceCompatibility)
at Microsoft.AnalysisServices.AdomdClient.AdomdConnection.ConnectToXMLA(Boolean createSession, Boolean isHTTP)
at Microsoft.AnalysisServices.AdomdClient.AdomdConnection.Open()
at Microsoft.Dynamics.Framework.Portal.UI.WebControls.AnalysisServerHelper.CreateAndOpenConnection(Boolean applyEffectiveUserName, String connectionString)
at Microsoft.Dynamics.Framework.Portal.UI.WebControls.AnalysisServerHelper.ExecuteQuery(String mdxQuery, IEnumerable`1 userParameters)
at CustCashInflowvsCashOutflow.GetCompanyAccountingCurrency() in c:\Program Files\Common Files\Microsoft Shared\Web Server Extensions\14\TEMPLATE\LAYOUTS\ep\CustCashInflowvsCashOutflow.ascx.cs:line 72
at CustCashInflowvsCashOutflow.SetDefaultReportParameterValues() in c:\Program Files\Common Files\Microsoft Shared\Web Server Extensions\14\TEMPLATE\LAYOUTS\ep\CustCashInflowvsCashOutflow.ascx.cs:line 49
at CustCashInflowvsCashOutflow.Page_Load(Object sender, EventArgs e) in c:\Program Files\Common Files\Microsoft Shared\Web Server Extensions\14\TEMPLATE\LAYOUTS\ep\CustCashInflowvsCashOutflow.ascx.cs:line 22
at System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e)
at System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e)
at System.Web.UI.Control.OnLoad(EventArgs e)
at System.Web.UI.Control.LoadRecursive()
at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
