Greetings,
After installing SP and EP.
From AX when I open the Role Center from System Administrator => User Profiles and then View Role Center. It give following error:
An unhandled error has occured. To vide details about this error, enable debugging in tehweb.config file or
view the windows event logs.
Event log as follows :
An unhandled error has occurred. To view details about this error, enable debugging in the web.config file or view the Windows event logs.
Either the user, domain\axadmin, does not have access to the Dynamics AX initial database, or the database does not exist.
Microsoft SQL Server 2014 Analysis Services
at Microsoft.AnalysisServices.AdomdClient.AdomdConnection.XmlaClientProvider.Microsoft.AnalysisServices.AdomdClient.IExecuteProvider.ExecuteTabular(CommandBehavior behavior, ICommandContentProvider contentProvider, AdomdPropertyCollection commandProperties, IDataParameterCollection parameters)
at Microsoft.AnalysisServices.AdomdClient.AdomdCommand.ExecuteReader(CommandBehavior behavior)
at Microsoft.AnalysisServices.AdomdClient.AdomdCommand.System.Data.IDbCommand.ExecuteReader(CommandBehavior behavior)
at System.Data.Common.DbDataAdapter.FillInternal(DataSet dataset, DataTable[] datatables, Int32 startRecord, Int32 maxRecords, String srcTable, IDbCommand command, CommandBehavior behavior)
at System.Data.Common.DbDataAdapter.Fill(DataTable[] dataTables, Int32 startRecord, Int32 maxRecords, IDbCommand command, CommandBehavior behavior)
at System.Data.Common.DbDataAdapter.Fill(DataTable dataTable)
at Microsoft.Dynamics.Framework.Portal.UI.WebControls.AnalysisServerHelper.FillTable(DataTable table, IDbCommand cmd)
at Microsoft.Dynamics.Framework.Portal.UI.WebControls.AnalysisServerHelper.ExecuteQuery(String mdxQuery, IEnumerable`1 userParameters)
at CustCashInflowvsCashOutflow.GetCompanyAccountingCurrency()
at CustCashInflowvsCashOutflow.SetDefaultReportParameterValues()
at CustCashInflowvsCashOutflow.Page_Load(Object sender, EventArgs e)
at System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e)
at System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e)
at System.Web.UI.Control.OnLoad(EventArgs e)
at System.Web.UI.Control.LoadRecursive()
at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
