Role Center error while opening AX 2012
I assigned a role center for my user and when i tried to open AX it throws the error.
When i checked in event viewer, it shows like this:
An unhandled error has occurred. To view details about this error, enable debugging in the web.config file or view the Windows event logs.
Either the user, does not have access to the Dynamics AX initial database, or the database does not exist.
Microsoft SQL Server 2012 Analysis Services
at Microsoft.AnalysisServices.AdomdClient.AdomdConnection.XmlaClientProvider.Microsoft.AnalysisServices.AdomdClient.IExecuteProvider.ExecuteTabular(CommandBehavior behavior, ICommandContentProvider contentProvider, AdomdPropertyCollection commandProperties, IDataParameterCollection parameters)
at Microsoft.AnalysisServices.AdomdClient.AdomdCommand.ExecuteReader(CommandBehavior behavior)
at Microsoft.AnalysisServices.AdomdClient.AdomdCommand.System.Data.IDbCommand.ExecuteReader(CommandBehavior behavior)
at System.Data.Common.DbDataAdapter.FillInternal(DataSet dataset, DataTable[] datatables, Int32 startRecord, Int32 maxRecords, String srcTable, IDbCommand command, CommandBehavior behavior)
at System.Data.Common.DbDataAdapter.Fill(DataTable[] dataTables, Int32 startRecord, Int32 maxRecords, IDbCommand command, CommandBehavior behavior)
at System.Data.Common.DbDataAdapter.Fill(DataTable dataTable)
at Microsoft.Dynamics.Framework.Portal.UI.WebControls.AnalysisServerHelper.FillTable(DataTable table, IDbCommand cmd)
at Microsoft.Dynamics.Framework.Portal.UI.WebControls.AnalysisServerHelper.ExecuteQuery(String mdxQuery, IEnumerable`1 userParameters)
at CustCashInflowvsCashOutflow.GetCompanyAccountingCurrency()
at CustCashInflowvsCashOutflow.SetDefaultReportParameterValues()
at CustCashInflowvsCashOutflow.Page_Load(Object sender, EventArgs e)
at System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e)
at System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e)
at System.Web.UI.Control.OnLoad(EventArgs e)
at System.Web.UI.Control.LoadRecursive()
at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
