In Classic Client while i am creating , create Layout suggestion and default layout is creating but while executing ,report is printing empty
Can anyone tel me why this is happening …
Neha
Neha
This has been discussed lot of times…
Create layout suggestion will only suggest 10-15% layout and dataset…
You have to check the dataset result and the problem to corrrect…
Ho k tanx Mohana…
Neha
Depends on the report too - I had to re-design a custom sales invoice that used the typical Page/Copy Loop/Integer virtual table setup - the header info in the classic client was defined in the Page Loop header, but that did not come over to the RTC layout. I had to create a copy of the report and re-design to populate the data elements in the data item header section I created - then the data came over to the layout.
Reports are 50% of my RTC conversion project time - easily. That one report took nearly 40 hours to get 100% correct.
