I’ve 7 dataItems in report one is Transfer Shipment Header dataitem other are integer and i also make code in the trigger of that item’s header,body,transheader… sections . that all are working well in classic report, but when i conver it into rdlc for RTC through create layout suggestion it is not working. Help Me How can i make report for RTC like that.
As I already mentioned you the section triggers will not be triggered when you run the report from RTC. You need to change the logic and write the code in data item triggers.
But when I design RTC Report My DataItems Not show and not their header and footer.so how can i manage this.I am new to Navision.so Rply in Detail.
plz Help me. i’ve an dataitem value integer and name=printsinglerec and in section designer i use printsinglerec header,transheader,body and trans footer. how can i manage these.
