Hi,everybody I want to un-install my Navision Attain version 3.01B on a windows 2000 operating system thru the menu “start/control panel/software” and i get the message that it can not un-install navision Attain because a file is missing. How can i solve this ? best regards, Naessens Wendy.
Hi Wendy, You might want to try re-installing/repairing Navision Attain 3.01 from the CD to see if this restores the file & then uninstall it via “start/control panel/software”. Alternatively, when you re-install Navision from the CD, you will be asked if you would like to uninstall it instead & use the uninstall wizard from there. Hope this is of help! -------------------------------- Edward Bloomfield Navision Support Consultant Cambridge Online Systems Limited www.cambridgeonline.net
Moved from Developer Forum to Technical Forum.
