Good Day, I have a issue with the Vendor Open Transaction editing, and the Marked total and Marked total valuta are not counting. If I mark some line transaction, nothing happens. Any one else that have this issue, and know how I can get the fiel to count as normal again?
Sorry for that, thought I had deleted the second one, thank you for fixing.
No changes in the standard, I don’t know how to debug since it just not sum up, and no errors. When you “mark” (in the check check box) a transaction line, AX should sum up in the field “Marked total”.
AP - Open Vendor Invoices - Settle Open Transactions - then when we mark a single or multiple lines AX should sum up the “marked” lines in the fields, but nothing happens if we mark one, two or three. It should count any way?
The marked total’s should be showing the value when the transactions are marked for settlement (unless the total of selected transactions is zero). Please have a developer to debug and see if there is an issue with code/data (bad data).
