Hi Experts,
Can anyone tried to install NAV2009R2 and NAV2013 on one PC.
Please tell experience.
Thanks & Regards,
Rishi Mohan
Hi Experts,
Thanks & Regards,
Rishi Mohan
Yes, I am having…
did you try to install them? what problem are you facing?
It’s showing reinstalling option
Are you sure you are using 2 different installers?
No i have single installer for NAV2013
What about NAV2009R2?
NAV2009R2 already being installed in the PC.then, should i uninstall 2009 R2 then install NAV2013 ???
I forgot which one i installed first…
but i dont think if NAV2009R2 is already installed then we should not get any issue in installing NAV2013.
Are you sure you have downloaded correct versions only…
When I check created date of 60 and 70 under Program Files then NAV2009R2 was installed first and then NAV2013…
Thanks for suggestion
