Installation Problem in NAV2013
Hi Experts,
I tried to install NAV2013 in my colleague PC it installed well his config is 2 GB RAM, and Intel Core i3 Processor.
But when i tried to install NAV2013 in My PC it showing Following error my PC config is 2 GB RAM and Intel Pentium 4 Processor
What’s the reason behind on it may be Old Processor or Other please guide me.
Thanks & Regard,
R!SH!
Did you install NAV2013 in your pc before?
if yes, Uninstall completely from Programs & Features and then re install again…
No Mohana,
I haven’t installed yet…
Rishi,
It is showing that Nav 2013 is installed in your machine and may be while uninstalling the same some of the components not uninstalled correctly. Kindly check in control panel as well as when you run NAV 2013 setup it will show the option to Remove the programs if it is previously installed.
Dear Amol,
I have seen every where add/Remove program as well command prompt where all the list of programs which are installed in that PC.I think in My PC NAV2009R2 is installed that’s why NAV2013 is not getting install.
Because when i click on Re-install option then its not taking any action further…
