I wish to install NAV 2013 and study the new system. but currently i had my nav 2009 installed in ma machine… I use the fin.exe for NAV 5 to open in the same machine. Is there an option to install 2013 the similar way… cos i don want my 2009 to be disturbed while installing 2013… But at the same time … i need 2013 too… Wat will be a good suggestion for me?
Thanks in advance,
Rekha.
We can have both NAV2009 and NAV2013 on same machine.
Hi Mohana,
Tats good to hear. Please help me to download 2013 and wat r the system requirements. Wat r de steps i should follow to keep two versions of NAV while installing 2013?
Rekha.
Hi Mohana,
I am trying to download the world wide W1 version from the link u send me. If i simply install it, wont it affect my 2009 in the system? Or should i try the fin.exe to open the 2013 jus like i do for Nav 5.
Rekha.
You can run NAV2013 only in RTC.
Finsql.exe (developement Environment) is only for developing.
Dear Rekha,
Did you ever find a solution to your problem? If you did, would you mind sharing it with us and if any of the posted answers helped you on the way, then please verify them.
Thank you.
