Hello there,
I am trying to figure out the best way do the following:
Delete a PO that has been received but not invoiced.
Reverse a a PO that has been received but not invoiced.
Reverse a PO that has both been received and invoiced.
Please advise,
CK.
1 - you can only delete a PO when the quantity received is equal to the quantity invoiced.
2 - from the posted receipt, from the functions button: Undo Receipt. I don’t know if that also updates the original PO and you can delete it from there, I’d have to try that out
3 - create a purchase return receipt, and post it. When you create the return order, you can use the ‘Copy Document’ functionality, which allows you to get the same information in there from a posted document.
1-True. This works as stated.
2- The undo receipt works for inventory items. It does not work ofr G/L items.
3- In my case I do not have a Returns Management Granule. I can only use the Purchase Credit Memo for invoiced items.
How can I get around without using the purchase return receipt. Or should I consider getting the Returns Management Granule?
CK.
If you are talking about GL lines then
- You must invoice it and credit it.
- Credit it.
I would not consider returns management for GL entries.
If you are talking about inventory items
- Unreceive and delete.
- Raise a return order and credit it.
I would consider returns management for Inventory items.
Thanks for all the answers. They were great.
