Hi all…
I have some problem with AX 2009. I did counting journal for stock opname and to adjust the stock at my company 2 weeks ago. I wrote the counted stock at “counted” field. If the quantity is bigger than “on-hand” there will be no problem, but if the stock at counted is less than on-hand (so the quantity is minus), I can’t post the counting journal and there’s an infolog: (number of minus quantity) can’t be picked because only 0.00 is available from the inventory. Till now, I can’t post that journal.
Here’s the example:
Item number W123 → onhand: 632 → counted: 58 → quantity: -574
Infolog : -574 cannot be picked because only 0.00 is available from the inventory.
The question is: How to solve the infolog? Because there’s so many lines with log, so I can’t finish the stock opname.
Thanks [:D]
