Hello, I have been given a table in FOB format by my partner. How can I import this as a table? I have Navision Navigator 4.0x.
Thanks!
John
Thanks!
John
Hi John,
I recommend talking to your partner as there may be data patching needed.
If it is a simple update then use Tools → Object Designer. When the list loads then use File → Import. As with all modification it is best to test on a test database. Also to save the current object, use File → Export first with the table object highlighted in the Object Designer.
Thank you. That was what I needed.
John
Glad to help [:D]
