I’m trying to show the currency symbol € when print an ammount in a report setting de format property as € , but ammunt format not changes.
As a walk-arround, I added a Label with the € symbol beside TextBox containing the ammount … it was fine until I was requested to hide ammounts when value is Zero. Now I set the BlankZero property to Yes in the textboxt containing the ammount but I’m unable to hide the € symbol.
It;s me once again. This topic had caught my attention. What do you mean I should not add my LCY to my list of other FCY currencies? You mean if my LCY is USD then it should have not listed on my list of currency? If yes, then why? What must be the effect?
Also, if I want to change the current exchange rate for example at any given time during sales/purchase invoice do I still need to go at the currency list to change rate?
Please confirm. That was how I understood from previous forums.
Hi thanks for the reply. Well in my case I set up my list of Currencies as GBP, USD, JPY. My LCY is USD, and I also added USD in my currency list. Would that be a problem?
Because Modris got me confused. It may be a mistake. Then early as now while I am starting to set up my company, I should have know to change it if it was wrong.
Hi, thanks for the info. Now, what would be my currency used for my customers and suppliers with the same currency of my LCY if if not going to add my LCY to my currency list? How will NAV know that the supplier or customer is in LCY?
