i’m a french new user of NAV 9 and I don’t know well how it works yet [:$]
I’m wondering how to easily “isolate” products : when some pieces should not be used because they are not in conformity, we don’t know how to do to make them not available.
We are using warehouse management, with lot of options and it’s quiet heavy to use. I was thinking about creating a new warehouse to put the bad products in , but it’s a lot of manipulations for the end-users to do that.
One approach used in MFG setups is introducing a intermediate Location, where all parts needing QA are recieved, and only those which pass quality tests are moved further to Location(s) of “raw materials”.
So you can control, how many “deffective” parts are left after QA testing, what to do with them further - return to Vendor, repair or write off as scrap, plus, no need to worry about parts in “raw materials” location - there appear only those that passed testing, and can be used in MFG, and you always know exact stock amounts of “raw materials” available.
Your suggestion will block the Item completely - Poutz IMHO is willing to block out some deffective / otherwise not suitable for MFG pieces of overall Qty of Item…
