I would like to downgrade NAV 2013 R2 REPORT IN TO NAV 2009 R2.
can somebody suggest me the best way.
Anil.
Anil.
Nice question. Wonder if there are other answers than: “redo the whole job manually in NAV 2009 R2”.
Because:
yeah. I thought so…!
I even tried to compare the .txt version and tried to merge it but since as you said the RDLC part is different. i found it hard to merge the changes and i finally raised up that even that text merging is also not possible.
The only answer i can see for now is to “redo the whole job manually in NAV 2009 R2”. as you quoted initally
Anil.
