i am trying to convert the nav 2009 report to Nav2013 but in nav 2103 we dont have section then where we should write the code of section in nav2013 and how to go with Groupfooter, transfooter and footer.
You should Convert your report in NAV2009 only and when your report is running in RTC perfectly in NAV2009 then only you need to move the report to NAV2013.
Better place to move Sections code is Dataitem OnAfterGetrecord…
thanx dear it i’ll try
