I have two Version of Sales Order Reports.
Fist Version is a Customer Customized NAV 2013 Report which is upgraded from NAV 2009 RDLC.
and the Second is a NAV 2013 R2 VS 2013 Sales Order.
Have any one a Idea how I can Merge the two Version of Reports.
I mean the RDLC section not the C/AL Code section.
Hi Manulektro,
Good question which points directly to the weakness of RDLC reports. There is simple way of doing this (and i am still hoping I am totally wrong). This is the reason that MS has spent a lot of time and money on upgrading and localizing standard reports and the background of why for NAV 2009 some local and localized reports had not been released with RDLC.
Hi Luc,
That’s isn’t what I mean.
The RDLC is Customized of our customer.
He want to have a upgrade to NAV 2013 R2 RDLC.
So I must Merge the Complete databases.
But if I Merge the RDLC with Araxis / Winmerge I can’t extract the customer difference’s to Merge these two reports
IMHO it’s the same issue as you cannot (easily) merge customization in RDLC from one report (version) to another.
IMHO it’s the same issue as you cannot (easily) merge customizations from one report (version) to another.
Just give a try.
First import the NAV2013 Customized object in NAV2013R2 database and compile it. This will convert the report to NAV2013R2 format.
now export it and compare with NAV2013R2 standard object.
