Nothing constructive from this reply…
But more likely you’d better contact your NAV Vendor. To find out which part of objects when wrong during upgrade.
Thanks, but I upgraded it by myself , so I don’t want to contact suppliers.
I would check your config files for both the client and service tier to make sure that they have all of the appropriate key / value pairs. These are probably loaded via the .NET Dictionary class, which would give a similar error.
Thanks!
ClientUserSettings.config
<?xml version="1.0" encoding="UTF-8"?>CustomSettings.config
