this is Prasad, I installed the NAV 2009 in two tier environment with developer options,and i configured the server and it is working fine through finsql.exe.while i am connecting through RTC,its showing this error in localhost& Client side also.
“” a server was not found at 'net.tcp://localhost:7046/DynamicsNAV/Service.'either the URL is incorrect or the server is currently not available.""
I enabled the services Dynamics NAV & Net.tcp with “Ntauthority/network service” and i didnt change any cofiguration file"CustomSettings.config".and i configured in server ,a new database and new companys on it.Demo database also is there.i successfully uploaded the Devevloper License file also.
What is the problem,can you please suggest me on this problem?
In my last post,we uploaded a wrong license,thats y i got that error,and i contacted to microsoft,and we got a new license,uploaded successfully.So the Last posted issue has resolved.
Thanks for reply, i followed wat u said above info.I changed the database name which i created new database manualy manually.But i got the same error.
Demodatabase is connecting in the local system,before changing the demodatabase name in coustomsettings.config file.it is connecting in only local system where i installed NAV server,mssql server and its not connecting in client side system.the error in client side is the same like above error.
I am able to connect the new database from client side through finsql.exe,but unable to connect form RTC.My SQL server is in Mixed mode,with this option getting any problem for that?
From server Mechine also i am unable to connect the new database from RTC.i got the same above error while connecting in server also.can u please suggest me?
