The FA G/L affects both FA Ledger and General Ledger, the other - only FA Ledger with no trace in GL Ledger.
There is a FA Posting Type field - select what you need there, I suppose your choice might be either Write-Down or Appreciation -these are used to adjust Book Value.
Maybe even Dispose, but that depends on what you have in your auditor’s list and therefore what your goal is.
I did not adjust the fixed assets at the year end. My auditor just gave to me in May, and I have calculated my depreciation all along for 2011 and some of the assets took off from the book. What do I need to do in this case?
This is the information that I have to complete in FA G/LJournal table.
Posting Date - 12/31/2010
Document Type -
Document No. - GL No automatic generate from the system.
You need to cancel all depreciation entries for the FAs in question created in 2011 first - Navision will not allow you to post anything before the date of last existing entry (and they are incorect, as BV actually must be different from Dec-31-2011)
How to do this - it’s a lengthy process, as you must do it for every FA one by one. (in fact, it can be done in bulk - but if you are a beginner in FA, I simply would not be able to describe the workaround method to you, sorry )
